Calls
02-27-2023 03:30 PM
02-27-2023 03:52 PM
@Piazza86 wrote:Just got new phone plan. I can only text on phone. Why cannot do outgoing /incoming calls?
@Piazza86 - what model of phone do you have? Can you try the SIM card into another compatible phone to see if incoming and outgoing calls work?
How about data, does that work?
Confirm your My Account status shows Active.
02-27-2023 03:49 PM - edited 02-27-2023 03:50 PM
@Piazza86 , did you submit a number transfer with the activation. That will definitely affect incoming calls, but outgoing should generally work fine. If your phone has a VoWiFi setting, make sure that it is not switched on.
02-27-2023 03:49 PM
@Piazza86 did it shows it connects to PM network? Any error like Sim not provisioned? No Network? No SIM?
You can text, but you could be using iMessage or RCS which was using your wifi
If you see it is not connecting to PM network. Try to reseat the sim card once again (or if you have dual sim slot, try your other sim slot)
If it still does not work, it likely a sim card provisioning issue, which is an easy fix on PM side. Just engage them via ticket:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
02-27-2023 03:31 PM
@Piazza86 Try to reboot the device to start
