10-04-2025
07:27 PM
10-05-2025
01:07 AM
computergeek541
I am trying to get into my other account, but the PIN is going to a phone number that is not my phone number with you. How do I get the PIN
10-05-2025 12:26 AM
if the phone number where the PIN is sent is not correct and you don't have a choice to get the code via email, you will have to ask PM to sort this out for you
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
10-04-2025 07:40 PM - edited 10-04-2025 07:40 PM
@jacksons wrote:I am trying to get into my other account, but the PIN is going to a phone number that is not my phone number with you. How do I get the PIN
If you click on "Didn't Get The Code" there should be two options. Send to Email, Send to Voicemail. If you don't have email, send to voicemail. Then you can call your phone from another and check your voicemail for the code.
Then when you finally get in, you can change the number HERE to your number.
10-04-2025 07:30 PM
can you see "send to my email" ?
