09-21-2022 11:09 AM - edited 09-21-2022 06:41 PM
UPDATED POST: I logged in to check hours later and it is listed as active. Thanks everyone for your replies!
ORIGINAL POST: My plan renewed today and I am set up for autopay. The amount has been deducted from my bank account, my phone seems to be working fine, but when I log into my PM account, it says account suspended. Can anyone shed some light on this?🤔
My Account
Payment
09-21-2022 01:57 PM - edited 09-21-2022 01:58 PM
Accounts going through renewal usually don't get updated to active status till at least noon Eastern. Occasionally it can take longer than that but that's the general rule of thumb. You'll know once you get the text from 611 saying you have successfully renewed your plan. If you log in after that you should have your account status listed as active.
09-21-2022 12:18 PM
The notice is normal the day before your renewal day. Your account will be suspended/expired but the very small print indicates if you are on AutoPay or have sufficient funds to ignore the notice.
09-21-2022 11:47 AM
Do you have service at all? Ignore messages as long as you have service and your CC is charged.
09-21-2022 11:45 AM - edited 09-21-2022 11:46 AM
@tina9099 wrote:My plan renewed today and I am set up for autopay. The amount has been deducted from my bank account, my phone seems to be working fine, but when I log into my PM account, it says account suspended. Can anyone shed some light on this?🤔
@tina9099 They should really warn people that this will happen. As long as everything is working, ignore it. It is normal behaviour for the renewal process.
09-21-2022 11:26 AM
@tina9099 hi on the morning of your renewal it will always say that,yes it scares people when they see it and not expecting it but it's normal,as long as your services are working all is well 😀
09-21-2022 11:12 AM
Hi @tina9099 if the service is working , you should be fine
Login with Incognito mode later, maybe after 2 hours and check again. Sometime the renewal takes long and the status not updated until much later
