Accidentally changed phone number
Artemis
I accidentally changed my phone number and I would like my old one back. Happened about an hour ago. Is there any way to get my old one back?
@Artemis
Maybe but only if the number was from Telus. Check with a CS_Agent.
@Artemis It is possible to get it back as long as your old nomberwas from PM originally and not ported in from another carrier.   please open ticket with PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
walker1
@Artemis
Probably not.
But you might try.
Use the Chatbot Simon to get a service ticket started first.
