Need help asap
Yukkel
Just signed up
i accidentally deleted my esim
it wants to send me a code to the text number I can’t get into right now so I can’t login to my account.
2 REPLIES 2
slusagm
@Yukkel
suppose you can go back to the app and get a replacement eSIM for freem. But I don't think you can get in as the account not fully setup and you won't get the code.  You need PM's help. Open ticket using the orange Chatbot icon on the lower right, type the question Submit ticket and select Contact us to get to  the ticket open screen
eddieO
@Yukkel, are you able to click on an option that says "Didn't get the code"? If so you should be able to select to receive the code by email
If you are not getting the option to resend by email you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
