01-30-2024
08:32 PM
01-30-2024
09:15 PM
computergeek541
I need correct APN settings for my Ulefone armor 17 pro. This model is not shown when I use provided link for new APN settings. Other models are shown but menus differ
01-30-2024 08:52 PM
Compare the APN settings below, try to update it and save (on some devices, you will need to Create new APN profile instead of updating the current one)
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
01-30-2024 08:47 PM
sp.mb.com
01-30-2024 08:42 PM
Try this article, @Cpc1964
