9 hours ago
- last edited
7 hours ago
DR_PM
Neither my husband or I can place or receive calls, but everything else works. Anyone else?
13m ago
@Robert58 wrote:I’m from Yukon Territory problem here can’t make a call some contact work some don’t
hi @Robert58
the issue that most people here is an issue that affect Eastern Canada. I thinks your issue is unrelated since you are in Yukon. You should ask PM to look at your issue seperately.
You can submit a support ticket right at My Account and PM app using the Expert Messaging in one of these ways:
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
https://expert-messaging.publicmobile.ca
Remember: Support hours of operation: 9 AM to 10 PM ET
17m ago
I done all that nothing happened
18m ago
A device reboot should be all you need
if you have physical sim card, test the sim card on another phone and it will trigger a sim reprovsion and should resolve the issue quickly
Again, if issue persists, please open a ticket with PM Customer support and they can assist further. Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account. Select Start a Chat to begin:
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
19m ago
21m ago
My husband same problems care to share what you did to make it work
34m ago
HI All
Please try your service after a device reboot.
if you still encounter any service issue, reply here and open a ticket with Public Mobile customer support for further assistance. Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account. Select Start a Chat to begin:
46m ago
not just you...many customers reporting the same issue. Some in Ont have service restored. Not sure your location, but hopefully they will restore yours soon too.
48m ago
widespread voice call issue. I think data still work.
if you like, download a VoIP app like TextNow and use it to make calls until issue is fully resolved
49m ago
there is a big thread about the voice calls
try this:
For affected mobile users, toggling airplane mode can serve as a temporary workaround while remediation efforts continue.
or also try try Reboot your phone and reset network settings
50m ago
since this morning I have been unable to make calls. Is it just me? or is it my phone? I thought I have confirmation that my phone will work. Please check
an hour ago
hi all
Although it might be a system issue, a reboot is necessary to re-establish a fresh connection.
Please reboot your phone before trying
2 hours ago - last edited 2 hours ago
hi All
!!!! Service is coming back for some people in some area in Ontario and Quebec and other Eastern provinces.
Reboot your phone and try again
if same, wait half and hour and reboot phone and try again and it should work
Services are still down in Ontario and other provinces, regardless of what was stated just recently.
Customers continue to report service is down in Alberta, British Columbia, Manitoba, Newfoundland and Labrador, Nova Scotia, Ontario and Prince Edward Island.
Just tested my Public Mobile phone (which is for my child’s use) with my other phone and some services are still not working. Thankfully, at least the text messages are functional.
1) Voice mail is not working. When a call is made to either the voice mail number or the phone’s number, it shows the word “calling” on the screen, but does not call because there is no dialling sound.
2) The Public Mobile phone has been tested on three other phones. Service for the other three phones is from Fido and Rogers. All attempts to make a call from the PM phone to another one fail. The dialling sound is not heard, but the word “calling” appears on screen as if the PM phone is attempting to connect.
3) All calls, except for one from a friend’s Fido phone, failed to connect. That one successfully connected call was likely due to just plain luck and timing, since the service outages are reportedly sporadic and unpredictable. When a call is attempted from another phone to the PM one, the caller’s phone is silent (there is no call dialling sound) and the incoming call’s number does not appear on the PM phone’s screen.
4) This massive and widespread hours-long multiple service outage across multiple provinces has cut off access to emergency services, if the need to request such help occurs, since Public Mobile’s service outage has rendered the phone mostly unfunctional.
5) All functions from other phones with service provided by another company not operated by Telus are fully functional, so the problems are not caused by the PM phone or the other phones or the any of the other service providers.
Since I have two phones, the service for the first one is from another company and these problems are not caused by the phone and we know it is caused by this widespread service outage (not the phone); I am not going to reset anything on the phone for now
Any such dumb instruction from the Artificial Stupidity System is just it’s usual blanket blame the customer and “fix it yourself” direction.
Fix the cause of the problems permanently, now that it has to be done anyway; so this doesn't occur again.
Eventually, Telus will get it’s act together and will get this fixed and stabilized.
2 hours ago
2 hours ago
2 hours ago
Sorry did not read you msg fully . The chatbot said it was fixed
2 hours ago
No one told me. Both my wife and I have phones on Public Mobile, and we can only call each other only. Otherwise, it is still down.
2 hours ago
Who told you that? I don't see any update here
2 hours ago
2 hours ago
2 hours ago
I can’t make or receive calls on my public mobile cell. I’m in Ottawa - anyone else?
2 hours ago
2 hours ago
been told it was fixed. Only works between another public mobile user.
2 hours ago
No outgoing calls in Toronto.
2 hours ago
3 hours ago
I’m in NL I can text , but cannot make outgoing calls, I can receive them
3 hours ago
I am in the GTA and can't call or receive either!!!!
3 hours ago
I can make call now. Hope it won’t break again. Thank you so much.
3 hours ago
Not working in Nova Scotia. Can’t get incoming calls.
3 hours ago
widespread voice call issue. I think data still work. if you like, download a VoIP app like TextNow and use it to make calls until issue is fully resolved
But I don't think anyone talked about text issue, so, not sure if your case is the same. And does data work?
