APN settings for tethering and using as modem
doe
Hi. At https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/APN-settings/m-p/30197#M4079 thread it was mentioned that PM subscribers need different settings for data transfers from smartphones and for Wi-Fi tethering.
@CS_Agentplease check and let know the final answer.
Are APN settings for tethering for Android different or same as usual settings for data connection from Android device?
I.e. does APN sp.mb.com work for both data from smartphone and for Wi-Fi tethering or do I need to change APN to isp.mb.com each time I'd like to start tethering, and vice versa?
Also, if I connect to internet via dial-up connection configured at my laptop using smartphone with PM SIM card as modem:
1. which number do I need to set up as number to dial to, login and password? I assume they are *99#, blank, blank?
2. Do I need to make any changes to smartphone settings, like adding ",dun" (with the comma, but without the quotation marks) to APN type, as mentioned at https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/APN-Settings-for-Tethering/m-p/1767/h...?
Thank you.
srlawren
@doe no need to set up anything special on your laptop, just configure your mobile hot spot on your phone (e.g. give it your own custom SIM and password), then start up the hot spot, and connect your laptop like you would to any other WiFi network.
will13am
There is only one APN for regular data usage and tethering.  For some android devices, it may be necessary to put dun into the APN type field.
sheytoon
sp.mb.com works for regular data and tethering/hotspot.
Not sure why you need dial up connection on your laptop. Can't you just use wired USB tethering on the phone? It requires no changes.
