APN - how to set it up
Mogens_Eliasen
I understand that it is important to set up APN correctly in order to send and retrieve SMS to/from other countries.  But logging in to APN on the phone, I am asked a whole array of questions, and I have no clue what the correct aswers are, including what is the name of my APN.  Can somone clarify this to me?
Mogens_Eliasen
There is something here that fills in some of those fields automatically, and not with the exact same vales for everything.  I guess I am OK accepting these values?
I cannot turn the APN on/off  - is there a trick hidden in that?  Do I miss doing something here?  I is grey on my screen, indicating that I am not suppolsed to touch it and I can't.
Your reply blew my mind with awe....
iliusfaisal
Use those values
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
popping
Try the simple solution first before configure APN manually.
- enable data
- restart you phone with your PM SIM card inserted will configure your APN automatically
- If not, you need to manually configure APN as suggested above.
geopublic
These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F or 4D
Don't forget to save these settings and then select this APN as the active one.
If you need to know where to find the settings:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
