11-14-2019 03:23 PM - edited 01-05-2022 09:43 AM
ALL incoming and outgoing CALLS DOWN. NOT CONNECTING
'Cant complete calls' says 'long distance add on is not active. '
Voicemail and local calls fall into this.
Incoming calls are simply not going through.
No reason for this.
My last payment was successful. Up to date.
I have 15$/ month 100 minute plan.
I have 500 mins canada wide calls add on.
I am 10 days into the new cycle. There is NO WAY I have used them all.
I am around 6 months into my billing/ contract.
I have reset the phone.
I have been on self serve.
I have chatted to SimonBot and then submitted a ticket.
No response after several days from Public Mobile.
I see no way to fix this??
Any Ideas????
Causing me quite an issue.... always happens at a time when u really need calls!! Trying to secure employment - effectively causing me financial trouble.
If I cannot fix asap I will be leaving Public Mobile.
ANY HELP WOULD BE AMAZING.
M
11-14-2019 05:55 PM - edited 11-14-2019 05:57 PM
@mark_addison If your addon is listed on your overview page when you access your selfserve account then it's active. It automatically kicks in when you don't have any minutes left in your regular plan. If the addon doesn't show on the overview page then you need to purchase it via the payments addon tab.
11-14-2019 05:42 PM
fernie BC
worked great for 6 months.
I believe my add on is not activated but its not clear what to do...
11-14-2019 05:39 PM
Thanks I missed the private message.
Did not know that is how they would contact me.
11-14-2019 05:26 PM
no minutes remaining.
but like i said i have not used 600 minutes.
It says on my account
Which makes me believe I have this applied to account. Maybe this is somehow not active. How would I activate?
11-14-2019 04:32 PM
Where are you located?
11-14-2019 04:26 PM
Best to contact a moderator again. This is complicated.
11-14-2019 03:31 PM
@mark_addison wrote:ALL incoming and outgoing CALLS DOWN. NOT CONNECTING
No reason for this.
@mark_addison Access selfserve does it show your minutes counter? Does it show your 500 add-on? If not, that means they have been used up and you will need to purchase another 500 minute add-on to get up and running.
What happens when you dial 611 from your device? If you submitted a ticket and have not received a reply check your private messages. That is the envelope top right of your screen. If you don't have any private messages from a moderator then submit another ticket.
Any Ideas????
M
11-14-2019 03:30 PM - edited 11-14-2019 03:46 PM
@mark_addison Surprised there has been no response to a ticket submission. @Tiana_V ??
As far as what to do: login to your account; confirm Status is Active and you have minutes showing under Data & add-ons. If both true, try these tricks:
a) Lost/Stolen Trick
1. login to your account >> Plan and Add-ons >> Lost/Stolen Phone >> click Suspend Service >> logout
2. login to your account >> Plan and Add-ons >> Lost/Stolen Phone >> click Resume Service >> logout
3. wait a few minutes, reboot your phone and check for service
b) $1 Trick
1. login to your account >> Payment >> One TIme Payment >> follow the direction to poay $1 >> logout
2. wait a few minutes, reboot your phone and check for service
If neither work, get another a ticket:
click https://publicmobile.ca.ada.support/chat/ or the ? on the lower right of this page,
enter "refund",
click "Contact us",
click "Submit ticket",
login manually if your username/password are not filled in,
click the drop down menu (in the white area),
pick the topic that fits your issue and follow the directions to submit it,
If none of the topics are correct click Other/Something Else until you reach the blank form
11-14-2019 03:27 PM
When you log into your account - do you see any minutes remaining ? If not then you have used them up.
