How do I know top% in October 2019?
Jackhyf63
Can someone tell me how do I know what top% in October 2019 for myself,usually I got from email and this monthly I don't get any information for top% in October.
8 REPLIES 8
@cat2019 wrote:
so when I review "my profile", all the badges I saw is what I earned from the current month? Each month the badges will be automatically updated?
Reward badges are only yours if it tells you when you earned it. Sometimes, there's a bug that gives all badges.
cat2019
@hairbag1 wrote:
I'm not sure if I understand your question exactly. If you click on the icon to the right of the little envelope...then My Profile, scroll down to view your badges. Find the one for October 2019. If you didn't get notification, you likely didn't get into a bracket....like as suggessted by @PAULRANG18 .
Keep at it though... contributions from @Jackhyf63 are always valuable.
will13am
@Jackhyf63 , you did not get any badges for October and so no rewards.  This is your badge link.
https://productioncommunity.publicmobile.ca/t5/badges/userbadgespage/user-id/65156/page/1
Jackhyf63
Thanks everyone for quick replying!
hairbag1
popping
You will receive a community reward badge if you get at least top 50% badge on Tuesday Nov12.
@Jackhyf63 log in to your self serve account and look under rewards where it says community reward.  If it says 0$ then you probably didn't get a reward this month unless your renewal was in the last 5 or so days
PAULRANG18
You likely didn't get an email because you didn't get a reward. I don't think there is any way to find out your standing in the community.
