5g plans
Kithtyr
can i still sighn up for 5g plans if my phone is only 4g?  i dont expect to get 5g speeds of course.
golfball
The 5G plans have a higher speed cap, higher data allowances and unlimited data at reduced speed which will benefit you whether your device supports 5G or not.
Kithtyr
oh i didn't realize that it would benefit me in speed on the 4g network.  thanks
dust2dust
Plans here are all about speed. You can get 5G speed and 4G speed connecting to both the 4G LTE network or 5G network. Then it's a decision of amount of data and the value you place on that cost.
JRod
@Kithtyr
Yes you can. The 5G, 4G, and 3G plans are really just about the speed cap that PM puts on your device when connected.
If you’re on a 5G plan you can get speeds up to 250Mbps
If you are on a 4G Plan you can get speeds up to 100Mbps.
Most modern devices can achieve speeds higher than 100Mbps while on LTE so if your device and connection strength allow’s you will be able to see higher speeds on a 5G plan despite not having a 5G device.
Chalupa_Batman
Hi @Kithtyr
Of course. I have a 4G phone and on a 5G plan. I'm in it for the amount of data over speed.
Here is the latest offer worth looking at.
https://productioncommunity.publicmobile.ca/t5/Announcements/Limited-Time-Sale-60GB-Canada-US-plan-f...
Sansan
I suppose you could but that would be defeating the purpose of getting a 5g plan, no?
