500 mins one time Reward
Curly75
500 one-time Int'l LD bonus is this okay for calls in Ontario can some one let me know Thanks Curly_75
dabr
@Curly75      Do you make calls to any of the international countries mentioned on the list for that gifted 500 mins?  It might be better to save those mins for making international calls (which include US) and instead purchase the 500 Canada wide mins for $5 instead for your calls within Canada.
darlicious
@Curly75
Yes you can use them locally, across Canada, and almost every international destination offered by pm.
@Curly75   Yes, the Holiday bonus you got can be used for Canada wide calling for those with limited minutes or on the old Provincial calling plans.
If you have no other minutes add-on , it will kick in when automatically when your Canada wide minutes are used up (or you are calling out of province if you are on the provincial calling plan)
