03-17-2020 07:59 AM - edited 01-05-2022 09:58 AM
Hey Everyone,
My parents are each on the $15 plan which has worked well for them, but with everything going on I would like to give them extra minutes just in case.
Could I add-on the $5 Canada option to give them an extra 500?
Thanks!!!
03-17-2020 09:32 AM - edited 03-17-2020 10:59 AM
@TheOldVR
One other item just to be sure that you know about, check that they are definitely on the version of the $15 plan that has unlimited incoming calls. Then original version of this plan had 100 minutes of combined incoming and outgoing minutes. That was launched about a year ago. Then a revised version was launched quite soon after that added unlimited incoming calling. You have to actually make the plan change to the newer version of this plan to get the unlimited incoming calls. If on the old version, schedule a plan change for their next renewal.
AE_Collector.
03-17-2020 08:35 AM
I agree with all the others. Also, remember that add-ons are a two-step process! Depending on your current funds available, you may need to add money to your account, and then get the specific add-on you need.
03-17-2020 08:14 AM
Thanks Everyone!!!
Hope you're all well, home, safe, and with tons of toilet paper!!
03-17-2020 08:01 AM - edited 03-17-2020 08:02 AM
03-17-2020 08:01 AM
You sure can. The 500 minutes rollover every 30 days until used up.
Two steps to buy an add-on follow guide below.
03-17-2020 08:01 AM
Yes, @TheOldVR It's recommended as a fallback. It doesn't expire and stays on the account until used up.
