12-10-2022 03:25 PM
I recently signed up for the change from $35 for 3+2 GB of data at 3G speed to this plan. I spend $5 extra thinking browsing would be faster. I don't use or need that much data. Can someone give me an advice if that's a smart move?
Service
12-10-2022 03:47 PM
@acheung you can always try it for a month or two if you don't see any extra value you can change back or find a more suitable plan
12-10-2022 03:34 PM - edited 12-10-2022 03:36 PM
@acheung Speed change isn’t instant.. it does come though..👍the xtra gbs.. is worth the 5$😬
