Text regarding $5/mo 3G usage price increase
Sham_Madani
Hello, I just received a message that I’m going to charge 5$ more because of my device that uses 3G, I’m not sure why because I’m using 5G data on my phone & I don’t really understand the extra charge!
192 REPLIES 192
Double check your phone below. What type of phone do you have? It might not be on PM whitelist and if so, the reason for the message and rhe heads up for you to change your phone soon.
https://www.publicmobile.ca/en/get-help/articles/volte
DW88
Is the Oneplus 15 compatible with PMs VoLTE? My current phone is also affected and I'm looking at options.
it has to do with the phone, your phone might have VoLTE but it is not on PM's VoLTE whitelist.  So, if it is like that, your data might be using 4G or LTE or 5G , but calls will go back to 3G
confirm if your phone is on the whitelist by using the VoLTE checker at the bottom of this page:
if it is not on it, then sorry, you need to pay the $5 for now until you get a new phone.  And yes, you still need a new phone as PM will close down the 3G network in March 2027 and you would have no voice calls then
Siamakmas
Today I received a message from public mobile that there is going to be 5 dollars charge begining of the next month on my bill due to 3G network usage!
I don't use 3G network and my phone set up is on preferred 4G Lte network.
What's this about?
bronneyhui
Is there a place for me to check which phones are whitelisted instead of buying a phone first and found out it's NOT SUPPORTED?
hi @NT31
this is device dependent and not plan
check if you current phone is on PM's VoLTE whitelist or not, if not, you need a new phone
hi @hongtao_wang
some VoLTE capable phone can still not on PM's VoLTE whitelist.
@NT31 ,
Thisbis not about the plan that you are on, but your G7 is not supported by Public Mobile soon, so you will need to change your phone to one that will be supported after March 2027.
You can use the chatbot to submit a ticket.
hi @Chapman-Boss
Chapman-Boss
I got a msg that if I continue to use my device which is Motorola E5 PLAY Power and on 3G, my subscription will increase by $5 to become $30 ... if l switch to 4GLTE/5G I can avoid this amount I am not sure if this is device dependent - do I need to change phone?  What's going on if your saying l need to change phones are you going to buy all your customers new ones
hongtao_wang
I received a message saying my device is using the 3G network and may be subject to a $5 surcharge.
However, my OnePlus 8 supports LTE and VoLTE. During calls, the phone shows HD Voice and remains connected to 4G/LTE.
I believe my device may have been incorrectly flagged as using the 3G network. Could you please verify whether my account will be subject to the surcharge?
NT31
Hello wonderful people, I got a msg that if I continue to use my device which is Motorola G7 Power and on 3G, my subscription will increase by $5 to become $30 ... I am not sure if this is device dependent - do I need to change phone? I checked online rates for G4 & G5 they are less than $30 - I hardly use the texting capabilities... any insights or how to get the attention of customer support. Thank so much for your help and have a wonderful day.
I don't belive that your phone is on public mobile whitelist . It will revert back to 3g for calls, which is why you are receiving that message
But I would verify with Public Mobile directly.
cigarsmoker
do you have any timeline when PM will shut it down
umnikke8
4G LTE support and VoLTE are separate things. Further, each device needs to be white listed by Public for VoLTE support, so there are some devices that have VoLTE support but yet don't work with Public. It's possible Public may add some more devices to the list, but I wouldn't count on much, if any change in the list. If the device isn't showing up with VoLTE support in the device checker on the help page it's notice that the device is not going to work when 3G gets shutdown, https://publicmobile.ca/en/get-help/articles/volte
The $5 fee will only be temporary as a 'stick' to push people to move off incompatible devices, before the 3G shutdown happens and they lose the ability to make calls at all.
Matty6
Why don't they just say they want $5 a month more, instead of being murky about why this would apply? Pubic Hair Mobile has the worst customer service. So much so, that they leave it to their customers to resolve problems for each other. What a stupid **bleep**ing system!
umnikke8
If the Public checker says your device supports VoLTE and yet you got the message, I would consult with customer support to get to the bottom of this so you don't get surprised when 3G gets shut down.
cigarsmoker
ok just an old school guy trying to avoid the new tech. thank you for getting back to me.my phone is a samsung SGH-A847M that i bought in 2011 same battery never a problem just love it,can you recommend a phone close to that one,i have a pc i dont need one on my phone. again thank you for your time take care.
LB2004
Hello.  I received a message stating "Public Mobile update: Your device uses our 3G network. Starting June 15, 2026, you will see a $5/mo 3G usage price increase on your bills if you continue using this device. Your monthly price will change from $18 to $23.
Switch to a 4G LTE/5G device to avoid this amount on your bill starting on your following renewal. You can cancel your subscription without penalty until 30 days after the effective date of this change."
However, my device does support 4G LTE. It is a Samsung galaxy A31.  How can I inform public mobile.
Thanks
@All
MONAM1512
Public Mobile update: Your device uses our 3G network. Starting June 15, 2026, you will see a $5/mo 3G usage price increase on your bills if you continue using this device. Your monthly price will change from $36 to $41.
For more information: publicmobile.ca/sl/a3aVuPCB5E
Received the above message. I am using OnePlus 12 device which is a 5G/4G LTE enabled device.
I have set preferred network to 5G preferred. APN setting as Public Mobile. Operator name also Public Mobile.
I am confused as to why I am receiving this message. Can a Customer Service representative contact me please.
hector_PB
i got a text saying my phone is using 3g network and i will have a 5$ increase. my phone is 4g/lte. why am i getting this?
OrionSteel
That's the point of charging. Making you switch.
mike-in-deep
My phone checks out. Its volte compatible
hi @Mogy
it is not whether you have a 4G or 5G plan or whether your phone has VoLTE itself, it is whether you phone is on PM's VoLTE whitelist
Please use the VoLTE checker here to confirm:
if it show no checkmark besides VoLTE, you will need a new phone (paying $5 is not a long term solution as PM will end its 3G network in March 2027 anyway)
if you see a checkmark besides VoLTE, then you can ask PM agent to confirm.  Submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
OrionSteel
Thanks.
Status bar says LTE, and when I call it says G4, so all the tests I found online says my phone support G4 and volte.
However when I check suggested IMEI it fails.
I would not think Motorola would not be supported by PM. But if they don't I guess I have to switch. But it makes no sense since phone says it's using G4 when I call.
hi @Jpshum5
as it shows it is compatible, let us know what agent says
hi @mike-in-deep
it is the phone, not your plan.  You can use data on the LTE network, but not when it is using voice
check the IMEI checker here, if you don't see a check mark besides VoLTE, you need a new phone
Jpshum5
Hello Softech,
I have used my OnePlus 8 Pro since Sept 2020 (just under 6 years) and been with different mobile network operators. I know shutting down 3G has been an ongoing trend for awhile now.
cigarsmoker
how long do i have to use my phone before PM kills it
