3G or 4G
toddmatheson
Is 3G too slow or good enough for non video watchers?
toddmatheson
Thanks, not on quite yet but appreciated.
Timer
@toddmatheson
Plans with 3G speed good and enough
or check what your budget which plan and price like to pay..take look Plans (publicmobile.ca)
what your plan now?
HI @toddmatheson do you use it mainly for Youtube type of streaming ?
I use YouTube on 3G no problem.
With Netflix type of streaming, as long as you leave it with SD, it's not too bad with 3G plan, but it will eat your data fast if you are on $25 or $35 plan.
Meow
3G is more than good enough for daily life. When I use it occasionally, I never have desire nor will pay for faster net.
It's generally fine, but I have the opinion that if you're going to to spend $40+ on a plan, you might as well take one of the 4g speed plans.
Outdoorsman
@toddmatheson Hello I find 3g is perfect for your everyday needs it will play videos on utube no problem,I never had an issue
