08-19-2022
06:55 PM
08-20-2022
12:02 AM
computergeek541
One of my friends gave me a discount code but when i enter it, it says that it is not valid. Pls help.
08-19-2022 07:49 PM
good point as mentioned @dust2dust if you finished the activation
then contact support team by private message CS_Agent to add it.
08-19-2022 07:22 PM
Just double check the code. Once you confirm the code, you just send a message to a CSAgent to apply the code.
08-19-2022 07:20 PM
If you've finished the activation and all is working then contact the support people to have the code applied once you are certain it's the right one with the right letters/numbers.
08-19-2022 07:03 PM
contact your friend and take from them by copy and insert by paste,
and also here free 2GB data for 12 month,
enter your email and the same email you will be activated
in here: https://publicmobile.ca/en/on/
08-19-2022 07:03 PM
@hetviparikh245 Make sure you are using a O or a 0 they can look the same or an S or 5 can get mixed up also
08-19-2022 06:58 PM
Yes the one which u can refer to a friend
08-19-2022 06:57 PM
@hetviparikh245 Hi do you mean a referral code?
