3G data on a 4G plan?
FMW
Hi all,
Thanks in advance for your help.
I am a long time Public Mobile Customer. I recently changed my plan to the one below, effective August 16, 2022.
Since then, I have never seen 4G or LTE on my phone (when I previously did have LTE). It's always 3G. According to my usage history, I am using the data....
I've tried putting the phone on airplane mode, restarting it, etc. I also checked Public Mobile's coverage map to make sure I didn't happen to be in a place with limited coverage.
I'm sure it's a really obvious answer and I am just missing it 😅 but I am hoping someone can give me some advice...
Thanks!
FMW
You all are gold, thank you. IPhone 13Pro is the phone.
Solution was to go into Cellular Data options and change “Voice and Data” from 3G to LTE.
Thanks so much! This community is the best!
@FMW   it only takes 48 hours for PM to change the speed on the plan, so it is not right you don't see the speed or not connecting to it
But first, check your Preferred Network Type settings, make sure it is LTE or you have selected some option that included LTE (or 4G) there.  If it is on Automatic, you can try to manually pick LTE if it is on the list
And what brand and model is your phone?  Just in case it is your phone issue, you have another phone to test it?
If none of those work or you don't have another phone to test further, open ticket with PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Dunkman
@FMW
It usually takes a few days to be switch over from 3G to LTE speeds.  Since you already did the switch on August 16, the transition should be done.  Did you check your data speeds?  Public mobile will still use 3G for talk.
A few basic troubleshooting advice:
Reboot phone
Network reset of phone
Maybe try SIM card in another working phone. See whether same issue.  Determine whether hardware issue versus PM service.
Yummy
It usually takes up to 48 hours for speed to reach 4G limit.
