06-15-2026 11:35 PM
I see my cell show 4G network. How Come I get charge $5 for 3G network?,
08-01-2026 06:56 PM
It's a carrier decision
What phone do you have? Did you check the IMEI checker?
08-01-2026 06:49 PM
My phone works fine on wifi calling in Canada and the US.
I don't want to pay the 5$ for 3G I never use. Can I get rid of this? I have the 100-gig Canada-Mexico-US plan.
Been on it for years and it has always been good. Despite not having this 3g add-on.
06-16-2026 12:30 AM
@OOlivia wrote:My MOTO 4E have a function "Use 4G on phone call" . Do you think it help to turn on?
Public Mobile doesn't work with wifi calling so shifting to use 4G on phone calls shouldn't make any diff. Going forward, we need VoLTE capable cellphones that are recognized with Public Mobile...not all are.
@Sansan sent you a link to some info and at the bottom there's a device checker. If it 's not compatible, it'll likely have troubles when the 3G is retired in Manitoba and other parts of the country later on. (I think most non-compatible cellphones in parts of Manitoba have already shown to be un-usable)
06-16-2026 12:18 AM
06-16-2026 12:18 AM
06-15-2026 11:56 PM
The phone is registered in their system as not been compatible, so im sure that they will not be able to monitor if you use it this month, not use next month etc to determine if they will change you or not.
As long as it's registered in their system it should charge the fee.
The fee will be charged until you change phones or leave them. Once March 2027 comes ,they will not allow phone calls with the same phone.
Data and text messages will not be affected.
06-15-2026 11:53 PM
@OOlivia wrote:I am using MOTO E40. If I do not make call, will it be ok? How about Text message?
You're going to have to upgrade to a newer cellphone unfortunately.
06-15-2026 11:51 PM
the added $5 has to do with the cell you're currently using. Here's some reading about the shutdown of 3G...particularly in Manitoba and will spread to the other provinces soon.
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
06-15-2026 11:47 PM - edited 06-15-2026 11:48 PM
Check this post. You can use the IMEI to check your phone.
https://www.publicmobile.ca/en/get-help/articles/volte
06-15-2026 11:46 PM
Moto e40
06-15-2026 11:44 PM
You are using 4g for data and browsing. The 3G is for making and receiving calls.
You will need to a phone that no longer relies on 3g for phone calls once the shutdown is complete in March 2027. They will continue to charge fee $5 untill you switch phones, switch providers or the shutdown.
