Birding in Costa Rica
1Leona2333
I am soon travelling to Costa Rica for a birding trip for about 2 weeks. I want to be able to use my birding apps there. What do I need to do?
1Leona2333
Thank you everyone for your information. I really appreciate it!
sorry @1Leona2333
PM has no roaming service there and you won't  be able to use data there
for other app, you can use local data sim or travel eSIM
Chalupa_Batman
Public Mobile only works in Canada, the United States and Mexico. There is no roaming outside these three countries.
If I may make a suggestion though that might be worth looking into. You can download an app like TextNow, pick a local number to where you live now. This way you can make calls back to Canada if need be.
Look at getting a eSIM from Airalo. Airalo are "data" SIM cards. There you will have data to be able to use your birding app. Here's the link.
https://www.airalo.com/
