02-27-2024 08:18 PM
Is the $34 50 gb can-usa plan unlimited data? Does it also reduce to 512kbs after 50 gbs is used?
Thanks
02-27-2024 09:52 PM
@Tmoney No, it's not unlimited once you consume 50GB. Your only option then would be use stick to WiFi or purchase a data add-on.
02-27-2024 08:20 PM
@Tmoney .no sorry the CAN /US plans don’t include unlimited data . Just the non CAN/US 5g plans have unlimited data
