$34 50GB 5G Canada-US plan
DaveNguyen
Currently with koodo on the BF $34 50gb 4G plan. I do travel to the US once or twice a month to hit up costco and get cheap gas.
5G speed would be great. This plan includes roaming right? So I could use my Canadian # just like home with no additional charges, correct?
7 REPLIES 7
Way1
I switched my plan to this yesterday
keegygti
I had the same plan as you from Koodo but I switched to public. Never know how long this promo is going to last for, if Koodo gets this plan then I’ll switch back.
mixxim10
too bad this offer is not for current customers!
keegygti
Yeah my bad. I meant USA and Canada. Thanks for the typo.
golfball
@keegygti It's not all of North America, service works in the US and Canada only.
keegygti
Yes. You can use data, calls, texts anywhere in Canada and America up to 50GB. :). You won’t be charged for roaming or don’t have to worry about getting roam charges at all!
@DaveNguyen
that's true, the Canada -US plan allows you to use voice and data in US just like you are in Canada
