12-17-2023 11:44 AM
2FA text verification is being sent to a previous phone number I had with PM instead of my current number. My contact information is correct in my account profile, so how can this contact number be updated?
09-21-2025 09:46 AM
Thank you! Changing my phone number associated my Eversafe ID did the trick. To change the phone number associated with my Eversafe id, I logged into PM (via a web browser on my pc), went to "My Profile", and then on the right side of the page, I clicked on the "Manage Eversafe ID" button (see screenshot below). Again, thank you for pointing me in the right direction, I appreciate you.
12-23-2023 06:36 PM
Found the solution. You have to update both your profile AND your eversafe Identity, deleting the old number. Two separate entries required.
12-17-2023 12:06 PM
Thanks...that's what I was looking for!
12-17-2023 11:49 AM
If you did not receive or cannot receive your 2FA code by SMS - Click on: ‘Didn’t get a code’ and you will get more options. Chose email.
12-17-2023 11:48 AM - edited 12-17-2023 11:50 AM
@JoeTourist first, you can use "Didn't receive code " and then use "Send email" option to get the 2FA code
once you logged in, to to Profile page, click Manage EverSafe id and you can update the phone number there
https://myaccount.publicmobile.ca/en/account/my-profile
