Cannot login after number transfer
Kusk
Could not activate account with a transferred number from Telus. So I've activated the account with a public mobile number, then did the number transfer. Now my phone works with the transferred number. PROBLEM. When I try to log in now, Public mobile tries 2 step authentication by sending code to the original number the account was created with. Not the transferred number. Therefore I cannot receive code and cannot login. I need to update credit card info immediately. Please help. @CS_Agent
2 REPLIES 2
@Kusk
You can get the code via email and then update the 2FA phone number
When you are at the 2FA step, click "Didn't Receive code" or "Resend Code" and choose "Send email" to get 2FA
Once you logged in, go to Profile >Manage EverSafe ID and update the phone number.  Or if you are using the PM app, go to Account > Manage Login (Secured by EverSafe) to update the phone number
If you have trouble getting the 2FA code via email, Private message CS Agent and ask them to update the phone number for 2FA for you:
Sansan
Please message then directly.
You can send message now, but they are closed for the night and will reply to your inbox the next day.
