$29 for 20gb plan how to contact support?
MollyPumpkin
New in Town / Nouveau en Ville
Hi All, how do i contact agent to ask for plan change?
1 REPLY 1
Dunkman
@MollyPumpkin
This promo plan is intended for new activations only.
You can try to contact customer service to see whether they can change for you. If you are on then $15 plan or $25 plan, there is a higher possibility since you are upgrading.  However no guarantees.  YMMV.
Send a private message to CSA through the following link :
