02-18-2024
08:21 PM
02-18-2024
09:48 PM
computergeek541
Did anyone else notice data being used and billed through the night?Could it be Iphone updates?
My Account
02-18-2024 08:33 PM
PM does not update the data usage constantly. In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry. The early morning usage you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
02-18-2024 08:22 PM - edited 02-18-2024 08:23 PM
Hey @BevS
Public Mobile updates it's data usage twice a day. Usually at midnight ish. Confusing isn't it? But you can always check your apps to make sure they don't download data at night. Turn on WiFi before bed. Turn off auto updates. If you go into your app section you can see what's being used the most.
