03-23-2022 11:49 AM
Hi there!
I activated the monthly auto payment.
The website says that I will receive a +250 MB bonus after the activation.
Can anyone tell me when it is getting activated?
I appreciate your help.
Many thanks.
03-23-2022 01:25 PM
Thank you @Meow
03-23-2022 01:23 PM
@raalaeifar wrote:😁
How can I send a direct email to an agent?
@raalaeifar here you are:
03-23-2022 01:19 PM
03-23-2022 01:14 PM
@raalaeifar wrote:I will create a ticket and write to the PM about that.
If ticketing does not work send personal mail to agent.
But I would not hold my breath regarding your comment to agent. 😋
03-23-2022 12:58 PM - edited 03-23-2022 12:58 PM
This is a problem with wording, as @Meow said.
The website says +250 MB bonus with autopay.
Thank you for your help, people!
03-23-2022 12:34 PM
Meow: Only the $15 is set. The others need autopay on to get the extra data.
03-23-2022 12:32 PM
@raalaeifar wrote:I have only 250 MB active right now.
That is exactly what you will ever get with $15 Plan. 250MB is default autopay or no autopay and there is no additional 250MB for autopay.
I guess PM did not change wording for that plan
Based on their Plan ads I would assume higher plan do GET data bonus so $25 Plan should get 1GB of data with autopay? Somebody to confirm, please!
03-23-2022 12:29 PM
It looks like you got a total of 450mb (250+200) of data on your $15 plan but you are reaching near the end of your monthly 250mb of data before it starts to eat away at your one time 200mb of data.
Best if your turn off data in your settings to conserve data just encase you need it unless it is near the end of your renewal cycle.
Use home wifi or free Shaw or Telus wifi if you want to save your data to the end of your cycle.
03-23-2022 12:18 PM - edited 03-23-2022 01:24 PM
The misnomer is.....you get 250mb of data with the $15 plan....autopay or no autopay. The plan as mandated by CTRC must include 250mb of Data.
Edit. The CTRC mandate was for Telus to provide a $15 plan. Telus provided it through the PM channel.
03-23-2022 12:03 PM
Then that's it. You have what is offered. It's not 250 and another 250. As said earlier, it's just 250.
03-23-2022 12:01 PM - edited 03-23-2022 12:01 PM
The other reward (200 MB) shown in the photo is related to redeeming my points (5 points).
03-23-2022 11:57 AM
Look at your phone data usage and see if a bunch of data got used after activation. Apps and OS may have done so seeing the new internet connection.
03-23-2022 11:57 AM
Hi @raalaeifar do you see 250MB already on your My Account My Data & Add-on box? the 250 Mb will come with or without Autopay. So, you get 250MB , not 500Mb
03-23-2022 11:55 AM
@raalaeifar wrote:I have the Basic Plan.
I haven't received it yet!
@raalaeifar Make sure your data is turned on. Are all your other services working? Try restarting your phone. Look in your self serve, do you see a line that says 250MB at 3G speed?
03-23-2022 11:55 AM - edited 03-23-2022 11:55 AM
The 250 MB is said to be a bonus on the $15 plan but in fact it applies whether or not auto pay is enabled.
Just for clarity, the total data allotment on the plan is 250 MB. Some people have confused it to mean the base is 250MB with a bonus 250MB. That is not the case.
03-23-2022 11:53 AM
Can you call and text both directions?
03-23-2022 11:53 AM
03-23-2022 11:52 AM
You should be able to see it at Plan usage as that is default amount of data for $15 plan.
03-23-2022 11:52 AM - edited 03-23-2022 11:53 AM
@raalaeifar wrote:Hi there!
I appreciate your help.Many thanks.
@raalaeifar Welcome to PM! If your phone service is up and running your data should already be active.
03-23-2022 11:51 AM
What plan did you get? Most come with 500 MB bonus if you are on autopay
