03-09-2020
08:33 PM
10-26-2022
11:58 AM
computergeek541
My plan is $25 for unlimited province tal and Canada wire picture and text....
Now I can see plan with $25 and unlimited Canada wire talk and international picture and text and 500 mb and extra 500 mb with auto pay for total. 1 gb. ....
Can this plan be automatically changed or do I have to manually change to this plan..?
10-26-2022 11:55 AM
I'm also on this plan and wondering if it's ever been proposed to add say 500MB more data per month? I find in recent months Google Play and Chrome like to push updates at any time of day, and websites like to use up data as much as they can. That extra 500MB would take the little bit of pressure off each month and ease my mind.
03-21-2020 06:43 PM - edited 03-21-2020 06:44 PM
@1946Buck wrote:Is there a warning when your out of data in a monthly cycle, or can you check useage anywhere?
You should receive a text after 75% and 90%. Data will just stop when it's run out....no overage charges.
03-21-2020 06:39 PM
03-21-2020 12:40 PM
No, unused data in the month is not transférable.
03-21-2020 12:37 PM
@AdamLove wrote:I want to know.....
Of I have 1 gb with $25 plan.... If I don't use all that 1 gb... Can I use on next cycle.....
Thank you.
Nope...whatever is left over is lost. When your plan renews, you'll start over with another 1GB for use. Use it or lose it.
Welcome to PM.
03-21-2020 12:29 PM - edited 03-21-2020 12:31 PM
@AdamLove If you are referring to the regular plan data(500mb + 500 mb autopay bonus), then no, it expires each cycle. And can't be carried over to the next cycle.
03-21-2020 12:27 PM
I want to know.....
Thank you.
03-11-2020 03:04 AM
threads merged
03-11-2020 02:44 AM
@AdamLove, make sure when you do the switch, you will have two options.
Change Plan Now or Change on next Renewal Date
If you change select Change Plan Now, you pay whatever plan it is and it doesn't matter if you had an old plan from before and it still has 3 weeks left. Your Old Plan becomes your New Plan right away.
If you elect and select Change on the next Renewal Date, you could save a few dollars.
03-10-2020 10:39 PM
03-10-2020 09:27 PM
03-10-2020 08:48 PM
03-10-2020 08:47 PM - edited 03-10-2020 08:48 PM
@AdamLove wrote:Someone told me my plan is going to switch automatically from old $25 to new $25 revised with data and Canada wide unlimited talk...
Is this true...?
Nope...you have to do it yourself. Select the newer $25 plan to get it changed.
Log into My Account / Change Plan. (Change at next renewal)
03-10-2020 08:46 PM
Is this true...?
03-10-2020 01:56 AM
I do I find it great with 1g data all Canada free an never had hitch I was with 35 plan I wasn't using all data so 25 plan is great an I saved 15 Cash to
03-09-2020 09:01 PM
03-09-2020 09:01 PM
@AdamLove wrote:Do you recommend this plan...?
Definitely. It will add more data and Canada-wide calling instead of province wide. Since the price is the same, its a no brainer.
03-09-2020 08:58 PM
03-09-2020 08:56 PM
Thank you for all of your help.......
03-09-2020 08:52 PM
@AdamLove wrote:One more thing......
When I go to change the plan manually.... It says current plan unlimited provincial talk and unlimited international text....
Then the new plan it says $25 and just 500 mb and 500 mb bonus with auto pay....
My question is ..... Does this plan have unlimited talk and text to....?
Yes the $25 plan has unlimited talk (Canada wide) and unlimited global text (from Canada).
03-09-2020 08:52 PM - edited 03-09-2020 08:53 PM
@AdamLove yes see picture below. Canada wide talk.
03-09-2020 08:51 PM
03-09-2020 08:36 PM
@AdamLove You will have to manually change it. Login to your self-serve account and click on Change Plan. Select the new plan and make sure to select change on the next renewal so it changes when your plan renews.
