10-26-2022 10:42 AM
Hello,
I currently have the $40 for 4.5 GB at 3G speed with rewards (not points). Is it possible to switch to a different plan and maintain my rewards or does it automatically get switched to points? Was hoping to switch to the $40 for 5 GB at 4G. Seems like a no-brainer if I can keep my rewards.
Appreciate the help on this!
10-26-2022 11:44 AM
Thanks, @Metal1967 and @Meow 👊
Really apprecaite it!
10-26-2022 10:58 AM
Rewards are tied up with your Account, not plan so you can change plans (even every 30 days if you like) without losing any rewards nor add-ons nor bonuses.
10-26-2022 10:43 AM
@nathan8 Yes you keep rewards.. change away..👍
