04-06-2024
08:49 PM
04-06-2024
10:26 PM
computergeek541
Hello, I received this 240gb Loyalty package on 20 March, but it is no longer appearing on my account after I changed my subscription plan to a cheaper one. Was I supposed to stay on the same plan to keep the loyalty package, or what happened?
04-06-2024 09:03 PM
@FateBoruj - Any downgrades from plans will make you pernamently lose the bonus data forever... ever... ever. 😔 Not really ideal for most users since they use less than 240GB of data and sometimes less than 240GB for 5 months on Wi-Fi, though I think I use over 100GB of data just on the Mac on the unlimited telus purefiber internet. Then it is my phone.
04-06-2024 09:02 PM
it said on the FAQ that the special 150 days bonus will be gone if you change to a lower value plan
https://www.publicmobile.ca/en/bc/get-help/articles/move-to-public-points
Will I lose my special bonus data if I switch plans?
The bonus data will remain active unless your account becomes inactive, you switch to a plan of lower value or to an incompatible plan.
04-06-2024 08:52 PM
@FateBoruj Yes downgrading plan will result in losing the bonus data add on unfortunately
