09-18-2024
09:03 PM
09-18-2024
10:09 PM
computergeek541
Hi just activated 3 lines today.
The first two activated quickly, 3rd is wacky .
Currently I cannot log in. I input my email and password, then the special code, then after nothing happens.
Second issue:
In the app it says I still have to finish activating.
It asks me to input the SIM # which I do, then it says its already activated and I cannot go any further.
It has been 4.5 hours since I activated this line and nothing works. (data/text/calls)
Any input on this SIM card issue? Or should we give it more time ?? I tried to reset network settings with no improvement.
(It's not a phone issue as another SIM works on that phone. )
09-18-2024 10:27 PM - edited 09-18-2024 10:27 PM
@BKNS27 wrote:I hope you used 3 different email addresses for the 3 lines because only 1 account/1 email address.
If you did then you can contact the Porting Department by phone. I will pm you the number.
Please do not direct customers to the number porting team for issues that aren't related to number porting.
09-18-2024 10:23 PM
@dayton_604 wrote:It asks me to input the SIM # which I do, then it says its already activated and I cannot go any further.
As it won't proceed further into the activation, please double check the SIM card number. If it stil isn't being accepted, this SIM card has been used before and you'll need a new/replacement SIM card.
09-18-2024 09:10 PM
09-18-2024 09:09 PM
I used 3 different emails, correct.
09-18-2024 09:09 PM
hi @dayton_604
Login problem. Try using Incognito/private/secret mode on your browser
with your second issue, you are using the app? try uninstall and reinstall the app
For activation problem, you can submit by direct message:
09-18-2024 09:08 PM
