12-31-2022 02:21 PM
12-31-2022 03:21 PM
Ya I joined 3 days ago, but if I switched to the 15gb plan (currently on the 20) would I still get 3x points back?
12-31-2022 03:04 PM
@ltyler13 When did you joined PM? did you join when it offers you 3x points? The 3x points activation offer is for any plans , but it only depends if you go that 3x point offer when you joined
12-31-2022 03:02 PM
Ya, sounds like the big difference would be points (2 for the $40 and 6.75 for $45 because of the 3x points back). So that would make the $45 plan 15 cents cheaper, although I know you can only redeem points after you have 15
12-31-2022 02:40 PM
@ltyler13 depends if 15GB is enough for you. I guess it is wise to save the $5. Remember you have the one time 2GB from Christmas just in case you use up data on any months.
I don't have the crystal ball, but I think these 2 plans or similar one will stay. So, you can change it to another plan later if the 15Gb really not enough
12-31-2022 02:34 PM
Difference is Data. All other features are identical.
As for the points, see small print as some offers come with the 3x points for limited time.
12-31-2022 02:30 PM - edited 12-31-2022 02:35 PM
@ltyler13 If you're interested in either plan, then it's a good idea to schedule Change at Next Renewal option ASAP as it's more than likely that both are most likely to be removed from available plans anytime after today, although it's possible PM will keep them a little while longer.
edit: the promo code is only available to new activations.
12-31-2022 02:28 PM
Ya I saw in the footnote the $40 for 15GB says no Promo Code or special offers available (not sure what it means by special offer) but the $45 plan doesn't have that exception, is that a big deal or does it makes sense to just go with the 15GB plan?
12-31-2022 02:23 PM
@ltyler13 other than the data, other features on both plans are the same.
Yes, there would be $5 worth of points difference (depends if you are on 1x or 3x points at the moment)
