$15 plan / unlimited incoming
mdlbarata
Hi. My $15 plan included unlimited incoming calls but now that feature appears to have been removed. Is this a known problem?
@mdlbarata
that $15 plan has limitations so why not throw another $4 in the pot and get the $19 plan with Unlimited Canada wide incoming and outgoing calls, plus you get 1G of data to use. Plus it's 4G (supposedly faster) than 3G. As you've been here for some time, you likely have Reward Points you can redeem towards the cost of your regular plan.
mdlbarata
Thanks! I'll watch it closely to verify.
@mdlbarata
No change to the legacy $15 plan and it still  have unlimited incoming calls.  The plan details might not show clearly, but there is no change to the legacy $15 plan
