04-19-2022 08:01 PM
Hello I am waiting to get a phone plan until this promo is back, do you know how long that will be? Thanks.
04-22-2022 01:04 PM - edited 04-22-2022 01:06 PM
@softech wrote:
the promo is now back!!!!!
There are times when promotions don't end at the stated end date but continue on as unadvertised.
04-22-2022 10:09 AM - edited 04-22-2022 10:14 AM
04-20-2022 07:27 AM
Were you planning on activating the $25/1gb plan or the $35/3gb plan or higher? If you are activating the $35/3gb plan(+) then use 2GBBONUS promocode instead as it is still being advertised and it has no limited time expiry on the 2gb of bonus recurring plan data and you have the flexibility to change plans as long as you remain above the $35 plan threshold.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
04-19-2022 09:33 PM - edited 04-19-2022 09:35 PM
The 2GB for 12 months ends on April 29 ONLY if you have order a SIM card from PM between April 8 to 11
Current promotion of 2GB for 6 months could work until April 29 but only if you have submitted your email
How to Get this Offer:
But if you miss those 2 promotions, you can wait for the next one, they have similar one every 2 or 3 weeks, but the base price could be $25 or $35 and above, usually $35 and above
04-19-2022 09:22 PM
Yes I got this promo only last month and it wasn't widely advertised at that point but if you can find it somewhere you should still be able to use it
04-19-2022 08:10 PM - edited 04-19-2022 08:12 PM
I'd say you might still be able to get it, @daisymenelaws
See here:
Just be sure to add the code 12MONTHS2GB in the promo field on the activation page!!!
04-19-2022 08:07 PM
Best thing to do is to check in the Announcement section once or twice a month or check on FB ads.
04-19-2022 08:04 PM
PM is always running promotions. Just keep an eye out for them on the main page or under announcements.
