100 Minutes?
Ed404
Hello,
I was looking at the $15 plan and saw it has 100 minutes for calling are these anytime minutes or minutes within a certain time.
For example Primus Wireless offers 250 Daytime Minutes (7AM-6PM). this means before 7 AM and after 6PM calling is free and doesn't use any minutes.
Thanks,
Ed
20 REPLIES 20
@Ed404 wrote:
I'm not sure why everyone is confused about the minutes with free calling between certain times. Please look at my example it is a real plan offered at another provider. You all have iterated that Public Mobile does not offer this sort of thing.
Thanks
I wouldn't call them free they are just included in that plan.  For Pm the $15 plan has free unlimited incoming calls then
Ed404
Thanks
88cranston
@Ed404 wrote:
They aren't restricted minutes, it's free between 6PM and 7AM.
Uh. I think you are confused with other NON PM plans.
Like free calls from 6PM one day and 7AM the next day.....and sometimes free on weekends. I had a Telus plan like that in 2000. 49.99 a month and including all calls in BC and Alberta.
That's opinion. I see It as the opposite.  Its not free but included.  I see it as a restriction because it's not unlimited all the time.
There are no time use restrictions at all. As long as you have an active plan with unused minutes in either plan or add-ons...you're good to go.
Until now, we 've been conditioned to accept restrictions with cell phone providers. Not so at Public Mobile.
88cranston
Does PM have restricted minutes......don’t think so.
88cranston
@Ed404 will have to evaluate the needs before changing plans.
Ed404
@Ed404 wrote:
Do any other plans have special minutes like in my example?
No but why would you want a restriction? If you're concerned with running of minutes, you should consider the $25 plan.
88cranston
@Ed404 wrote:
Could I buy that 500 minutes add-on for one month and have it roll over so I have more spare minutes?
Yes. Just the unused of the 500 will rollover. The 100......use them or loose them😀
Once you have a regular plan, you can also  get that 500 minute Canada wide calling add-on. Unused addon minutes roll over until used up.
Ed404
@Ed404 wrote:
Thanks everyone for the information!
While you have the Public Mobile $15 plan with 100 Canada wide calling minutes...you can pair that plan with the $5 / 500 minutes of Canada wide calling add-on. Call anywhere in Canada, any time of the day or night...for 500 minutes. If you don't use all of the 500 minutes by your renewal...no worries....those excess minutes will roll over until you use them...even if it takes several month or more.
The $5 / 500 minute Canada wide calling add-on is a great addition to your limited calling plan.
Ed404
mimmo
There are no special minutes.
totalUser
Hi @Ed404
You get 250m if you use autopay
TextNow with restricted background data consumes about 30.
They give you free Canadian number and unlimited talk and text to Canada and USA.
It's best companion to 13 plan.
500 minutes for $5 add-on is also excellent option, very affordable.
Incoming minutes are gold, I would never trade them for unlimited evenings and weekends. It's when you call gvmnt or support that you use up most of your minutes and that's usually 9-4. TextNow is great for that.
Hope that helps
Cheers
PS. Don't forget to use referral it will give you extra $10
popping
All other currently available plans with call minutes have unlimited Canada wide incoming + outgoing minutes.
There was a $10 plan with 50 Canada wide incoming + outgoing minutes which is no longer offered by PM
Ed404
popping
@Ed404 wrote:
Hello,
Thanks,
Ed
The 100 minutes is any time, Canada wide, outgoing minutes and unlimited incoming minutes.
Dunkman
@Ed404
Anytime minutes, outgoing calls.  Unlimited incoming calls.
