09-11-2018 09:33 PM - edited 01-05-2022 01:45 AM
09-12-2018 01:00 AM - edited 09-12-2018 01:02 AM
@pyrotexhnics: Your term ends tonight at midnight so it has "expired". Check things in the morning and everything should appear renewed. Or mid-morning.
You're in this weird transitional time where reporting and counters can appear a bit screwy.
09-12-2018 12:54 AM
It's weird - it should show up here under "Overview":
In the "Plans and Add-Ons" tab, it shows this:
Not sure why it shows "Plan expired" but I am on autopay and I do have a balance of $29 in my account.
09-11-2018 09:49 PM
@mimmo wrote:@Anonymous the 400 minutes should be good to call Canada, usa and select international.
In the time it took after I posted, I verified my information and found I was wrong and edited my post and then saw your post rightly correcting me after that.
09-11-2018 09:40 PM
09-11-2018 09:37 PM - edited 09-11-2018 09:40 PM
09-11-2018 09:37 PM
Not at all, when the included minutes are used up, the add-on minutes are next to be used. Are you certain the add-on minutes are there? When you look at the overview tab, do you see 0/400 minutes?
09-11-2018 09:37 PM - edited 09-11-2018 09:39 PM
If the add-on shows in selfserve ie not used up then I would message mods asking for help.
How can you get help with your account, activation, or service?
In your message please include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
Some good posts/reads:
