1 of 2 failed porting from rogers sub. HELP!
dalewilliams
I have 2 numbers with one of a rogers carriers (Simply Connect).  One of the numbers ported fine but i'm stuck with mine not having ported.  I never did get the text, is there a way to re request the porting on my number to happen again over to PM ? Any help or guidance would be appreciated.
From what I can tell I've submitted a ticket and sent a PM to the CS Agents.  I
2 REPLIES 2
 @dalewilliams
I hope you didn't use the same email address to active your second number.
Only one account/email address.
If you did, create a second email.
dust2dust
Did you leave the old sim in and confirm the transfer?
Try the number in this link. Leave the old sim in a phone and the old account needs to be active.
https://forum.telus.com/t5/Mobility-Services/Help-with-porting-my-number-from-Rogers/m-p/123686/high...
