Reply
Phil89
Re: iPhone Update and APN settings
LTE data is still not working for me. 3G is working thou. I have gone thru the APN setting mention on the first post. Just wondering if anyone else is having the same issues? I own an iphone 5s.
DK
To the users of i4 and data the issue has been discussed before. It has to do with being able to edit your apn settings and the fact that Apple doesn't usually let you do it. If you are on a i4 you will need to go to www.unlockit.co.nz using your safari browser on the i4 in question and download the settings using the apn setup prompt on the website. Once that is done your data will work with no issues.
DK
bigabee
Re: iPhone Update
God bless you. I didn't know how I was going to get the APN onto my iPhone as I was having the same issue but the website you mentioned worked!!! Hooray!!! Thank you, thank you, thank you!!!!
DK
Re: iPhone Update
Glad it worked out for you.
Luddite
iMessage will work if
a) you use your iCloud account as primary, and
b) you have a Data Add On.
That's my set up and it works fine. Will even default to sms/mms if the recipient is not on iPhone.
makkahn28
Public Mobile is Forgetting to Add the Tethering info too.
If PPL wish to use their iphones as a Tethering hotspot, would be handy, Same for Windows, BB OS 10 Too
Chahnaz
I dont have internet  tethering in my ipone i have iphone 5c and the still not working what i do
Rockdaddy22
This just fixed my data, thanks op
Rockdaddy22
Try following the steps from page 1
