Reply
Highlighted
Re: iPhone Update and APN settings
@jgalpin580
I'm happy to hear everything is in proper working order!
Welcome to PM and the community!
Highlighted
Legend
Hello,
It was great to read that all is OK now.
Welcome to Public Mobile!
Highlighted
Thank you!! 👌😄
Highlighted
Re: iPhone Update
I have same problem with this in my Iphone 6S. Anyone can advice?
Thank you
Highlighted
Re: iPhone Update
Hi @Dudez2013, you should be able to change the default APN to sp.mb.com as in the first post.  Please check.
Highlighted
I'm on 6s changed APN everything works great
Highlighted
Thank you so much! This was a lifesaver!
Highlighted
Glad it worked out for you 🙂
Highlighted
Hi, I just purchased a 90 day cell, text and data plan and the data does not work. After emailing with PM they have't offered any useful solutions. Ive followed the steps to change my APN and all my settings are correct as indicated in troubleshooting and here in the community. I have an older unlocked Iphone 4 that has worked with many different providers with no issues, only now with PM. My account shows as 'active' and my credit card has been charged. Any ideas? Frankly, Im unimpressed so far.
Highlighted
Hello, with the Iphone 4 you need to do in order to fix the problem with the APN:
With your Iphone 4 click on  http://www.unlockit.co.nz/unlockit/ and follow instructions.
Good luck!
