Incoming calls
ztim
I don't receive incoming calls, it goes atumaticly to voicemail.
I can call and texting is good
7 REPLIES 7
t_p
@mattdxb @ztim
As mentioned above, setting your phones to 3G should solve the problem for now.
If you don't find the setting to do it, you can try this:
dial *#*#4636#*#* on your phone
select Phone Information then Set preferred network type to WCDMA.
mattdxb
@ShawnC13 @dabr
Thanks. Well, it seems to be have corrected itself within the last 10 minutes or so.
Calls seems to be going through. Testing with my home phone.
forgot to mention.. no, I'm in the GTA, not London area.
@ztim and @mattdxb, are you both in the London Area?  It seems to be an issue in that area and it could be hardware that is being updated causing the issue.
@mattdxband @ztim   Telus (parent company of PM) is upgrading their equipment in some areas and some customers are being affected so the suggested workaround (for now) is to temporarily switch the network to 3G/WCDMA setting on your phones.
mattdxb
Looks pretty clear to me this is a network issue as I am on Telus (not Public) and I'm having the same issue. No incoming calls but can make outgoing calls with no issue.
I only found out since my dad called me (via whatsapp) and told me he couldn't receive incoming calls either and he's on Public.
although it seems interesting that it doesn't seem very widespread. I'm not seeing many other reports aside from the PM subreddit
Triguy
Did you recently port your phone number over to PM ?
Make sure that you have do not disturb set on your phone.  Also try rebooting your phone.
@ztim
can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone
This is quick and simple,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
and you can try to reset network settings and Changing APN Settings
Spoiler
for IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
