VPN issues
06-30-2022
02:42 PM
06-30-2022
03:17 PM
computergeek541
Hi; I use a VPN as everyone should.
I can not connect to publicmobile.ca while using the VPN. or http://publicmobile.ca/get-help
I can connect to
https://productioncommunity.publicmobile.ca
https://selfserve.publicmobile.ca/
I know that you probably can not help, but this issue should be brought to someone at public mobile tech dept.
07-03-2022 02:23 AM
@Skilling wrote:Hi; I use a VPN as everyone should.
I agree that everyone should use a VPN.
I don't agree that everyone should use a VPN all the time. There are instances - like the one you describe - where sites fail or break when accessed through a VPN. The best cure in these instances is to shut the VPN off (for the duration) and access the site normally.
I could understand efforts to secure the Self-Serve servers by blocking connections from VPN exit nodes. I can see no gain from blocking access to servers which run stuff like Get Help FAQs.
But Public Mobile's websites are a mess. A buggy, half-misconfigured kludge, it always seems like Public Mobile is reluctant to adjust anything because they're afraid to break anything which already (mostly) works well enough.
07-01-2022 06:07 PM
I have tried numerous fixes.
Changing Protocols seems to work.
UDP, TCP, and Wireguard(on auto) do not work.
IKEv2 and Wireguard(selected, not auto) work.
Very strange!
07-01-2022 01:08 AM
Thank you for your comment,
As stated above, I use SurfShark, one of the most highly recommended VPN's out there.
Why would I change VPN's???
It is PublicMobile issue if they have it blacklisted.
06-30-2022 10:42 PM
@Skilling try changing the location
Try changing VPN provider, some probably got blacklisted
and which one you are using?
06-30-2022 05:04 PM
OK wrong VPN, I use SurfShark
06-30-2022 03:22 PM
Actually this is on a PC not a phone.
06-30-2022 03:20 PM - edited 06-30-2022 05:05 PM
I use SurfShark
06-30-2022 03:16 PM - edited 06-30-2022 03:17 PM
What VPN app are you using?
If you use an iPhone, I use Cloudflare and it has an option to disable for 15 minutes or an hour or when you enable when you are finished.
I have the same problem on specific sites and I disable for a short time because the anti-malware on this app find it suspicious.
I find Cloudflare doesn’t work as well on Android phones.
