08-31-2019 10:32 AM
HI guys,
When I write something to reply a message, it isn't appears under the main message. it is ok or there is a problem.
Thanks
08-31-2019 04:56 PM
@dabr wrote:
@sholeh wrote:HI guys,
Thanks
@sholeh If you are replying to the community forum, then you just need to click the dark reply button (bottom right) in the post you want to respond to. This will open up a dialogue box where you can just click quote (top right) and then type your response. Also if you want to tag someone just use your @ key and it will bring up a list of names, then simply click on the name you are responding to.
Thank you for your useful response.
all the best
08-31-2019 02:59 PM - edited 08-31-2019 03:02 PM
Thanks
