tried changing my phone number but now i can't call or accept calls
newfiebelle
I moved and decided to change my number to a local number.  Had no problem changing it but now my old number or my new number won't work.
7 REPLIES 7
@newfiebelle wrote:
yes, my new number is showing on my account info
@newfiebelle   It's odd then that it's not working for you.  Have you tried the other suggestions?
If those don't work, then I would submit a ticket to moderators by clicking the chatbot bottom right of the screen and following prompts.
Edit:  BTW you may also want to try topping up your account with $1 and rebooting your phone too if the other suggestions don't resolve this for you.
@newfiebelle wrote:
I've already tried restarting the phone.
@newfiebelle have you tried the other trouble shooting I mentioned?
Also log out of your Self Serve completely.
newfiebelle
Ok  trying those suggestions now.
newfiebelle
newfiebelle
dabr
@newfiebelle   Try rebooting your phone.
Also when you click on  Plan Details (under My Plan) on the overview page, do you see the new number that you picked there?
Hello @newfiebelle ,
Try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
