Reply
Transferring number from PC mobile
Hello who do I contact to transfer number from pc mobile.  In the sign up it said to pick a new number then contact after to switch number
thanks
Re: Transferring number from PC mobile
@Prw990, you will need to send a private message to the Moderator_Team.  Use the envelope in the upper right corner to do this.
Lazy now are we? Not even a link. Robot LOL
>>> ALERT: I AM NOT A MODERATOR. JE NE SUIS PAS MODERATEUR.
Hi Prw990,
When I transferred from PC mobile, I logged into My Account, select Plan and Add-Ons – Change Phone Number - Transfer a wireless or wireline number from another provider. Putted my old phone number, then filled the form. It was done within half an hour. Before I transfer my old number, I got a new number from PM and tested it first. Hope this helps.
Thanks for this info. I'm a new customer that transferred from PC Mobile. It was really easy. Smiley Happy
Note: I was using the Public Mobile data to make the changes, so the network went down. All I needed to do was close and boot my phone for the number change to apply.
