07-08-2019 04:42 AM - edited 01-05-2022 05:46 AM
07-08-2019 09:52 AM
07-08-2019 06:52 AM - edited 07-08-2019 06:52 AM
@Brow , please check your self serve account. If you see in the overview tab the right data allotment and the account in active status, that would indicate a normal renewal. If you are seeing that, then try the lost phone toggle as suggested. If the account doesn't look right or the lost phone toggle doesn't work, then you need to seek moderator team assistance.
The moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
07-08-2019 05:45 AM
@Brow wrote:I had my usual Plan renewal by way of auto pay but I can’t use my internet data !!!
From what I heard previously the "Lost Phone" Suspend/Resume Service was able to correct this for some.
07-08-2019 04:51 AM
