Reply
Overcharged
Hi I am on the $120 LTE plan minus $21 in rewards and have been charged $125.43 ... What gives?
Re: Overcharged
It should be Cost of plan - Rewards + Taxes. What were you charged last time?
Please contact Moderators if there's an issue. To submit a ticket: Click the green question mark at bottom and enter your question into SIMon. Answer the prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
If you encounter problems with submitting a ticket, you can also send a private message to Moderators, but this alternate contact method may have longer response time.
Re: Overcharged
What is the 120 plan?  Don't see it.  LovesToPM has given you the correct answer above.
Re: Overcharged
Thanks I submitted a ticket.  Wow wish I could just hit a contact us button without all the fluff.
Re: Overcharged
@gblackma  I believe Mikasik has a $40 plan with 90 days renewal. This option is no longer offered. New customers and anyone changing plans, have to choose from the list of current plans with renewal every 30 days.
Re: Overcharged
If it is the same legacy plan that some of us are clinging onto with both hands, its 90 days/unlimited province wide calling/unlimited text/12GB unthrottled LTE data.
Re: Overcharged
The so called fluff is analytics to gather intel on the nature of the problem.  Back in the day, you could just submit a request with the moderator team.  Unfortunately, without some structure many of the requests had little information about the issue that needs to be addressed.  As a result, there was a lot of additional back and forth messages.  The intent of the new system is to ensure that enough information is provided that the moderators should be able to work on the customer's problem right away without having to ask for more information.
Re: Overcharged
Thankyou. So province wide, not nationwide talk and  it's basically the $40 plan with 3 less gigabytes of data over 90 days with sutopay. Are there penalties if you switch? I.e. Will you lose your rewards if you switch.  Or is there some unknown benefit if you keep this plan?
Re: Overcharged
@gblackma
No penalty to switch.  Keep rewards credits.  This legacy plan included LTE data (unthrottled). That is why people want to keep this plan.
Re: Overcharged
With the $5/500 minutes Canada wide add-on for the occasional across Canada calls, this legacy plan is a perfect LTE plan with the flexibility to use more data in a month.
