09-21-2019 03:43 PM - edited 01-05-2022 07:13 AM
09-23-2019 10:50 AM
@chukdefatey wrote:
@hpepper wrote:Anytime I try to make a local call I am told I need a long distance add on to complete the call. Pease help!!
If you haven't run out of minutes then just manually dial the 10 digit number with a plus sign in front of it followed by 1. Example: +1-AAA-BBB-CCCC
Yes...it just does that if you don't put a 1 in front of the number. Almost everyone has Canada wide minutes so no calls are long distance they're just in Canada .
09-21-2019 05:57 PM
09-21-2019 03:51 PM
Did you run out of minutes?
What is the status of your account when you log in
09-21-2019 03:50 PM - edited 09-21-2019 03:57 PM
What plan are you on? Did you just sign up? Or was your calling working and then stopped?
