Samsung Galaxy S20 - details on compatibility with PM?
Chris4
Hi all, I'm considering purchasing the Galaxy S20 Ultra outright, and hoping to use on my Public Mobile account. A few questions I thought I'd confirm with the group:
+ Will the phone work on the PM network?
+ I believe the S20 will be 5G enabled - any word on when 5G will be available on PM? I'm assuming it's a long way away, given it'd have to roll out to Telus first, and then flanker brands like PM
+ Any other considerations you'd share if someone were purchasing a Samsung S20 for use on PM?
Thanks all!
derekb22
How would it work with only 3g streghth tho
Chris4
Thanks for the replies all, looks good to go!
pmmobile
@Chris4  It's usually a good idea to still ask the kiosk/store to put in a PM test SIM to ensure the phone itself will function properly, because if you discover an issue with the phone (not specs related), there are no refunds with PM
geopublic
@Chris4  Yes it will.
Correct.
Make sure the phone is unlocked before purchasing.
Thanks all!
Dunkman
@Chris4
This phone will work with PM.
https://m.gsmarena.com/samsung_galaxy_s20_ultra_5g-10040.php
As for 5g, who knows. PM is a lower tier Telus company. It barely has 4G plans at this time. Might be a while before 5G happens with PM.
No no other issues with this phone working on Public Mobile.
