Reply
Highlighted
MMS Won't Work, Tried Everything
Hey,
I got a new phone, HUAWEI P30 Lite.  I did everything on the forum such as adding a new APN and writing exactly what you guys recommend.  I restarted the phone, I still can't send or receive mms messages.  I even did a reset for my network settings, restarted phone and readded the APN.
I tried to send mms messages, it won't send. I tried receiving mms messages, it won't receive.  I tried enabling wifi, then switching to mobile data only...and still nothing.  If I browse the internet, wifi works and so does mobile data.  But MMS....zero luck! Please help.
Highlighted
Re: MMS Won't Work, Tried Everything
 @blessme4k
Try adding ,mms to the APN Type line. That's a comma with no spaces anywhere.
Highlighted
@z10user4
"You do not have permission from your carrier to add -Type APNs"
This is when i write " ,mms "
When I simply write "mms", it allows me. But when i restart, i still can't send or receive mms.
Highlighted
@blessme4k wrote:
@z10user4
I've not heard of that message before. But I don't know everything 🙂
You'll need default and mms and likely some others.
Maybe post screen shots of your APN settings.
Highlighted
Tried this just now:
http://prntscr.com/uh5ev4
I even tried it where I left the APN type blank or just mms. I also tried it with MVNO type as blank also.
Nothing...
Tried this also:
Highlighted
 @blessme4k
There are some subtle variations here and there.
I would still be focussing on APN Type.
But there's also
MMS proxy: mmscproxy.mobility.ca
MMS Port: 8799
My APN Type is default,mms,supl.
I've read here of blank MVNO fields too but I have GID and 4D in mine.
Highlighted
I've tried the first one too, that was my default settings originally. Still nothing.
Highlighted
hmm. Any chance for seeing those screen shots? Pictures tell a thousand words.
Your cell data is on right? It needs to be on to send/receive MMS. Or a toggle that would do it automatically.
Highlighted
IMG_20200914_125907.jpgIMG_20200914_130025.jpgIMG_20200914_125856.jpgI took a screenshot of three different settings:
https://prnt.sc/uh5r7n
Highlighted
I see nothing off with the first two. The right one doesn't have APN Type but you were probably testing that.
What do you have for those MVNO values?
Your phone can take it's own screen shots. But your method worked. 🙂
